#1880-Addon Message Credit Not working with Broadcasting
Rasool
Rasool
 Rasool
one of my client are in a plan 200k messages per month , they reached around 199k , now they bought a add-on of 300k , now it is showing 199k used out of 300k ( so having 101k ) , but trying to create a campaign for 3k subscribers , it got rejected due to insufficient credits,
i reset the credits ( now having 300k ) , now it is sending fine
it doesn't consider the Addon credits ( while sending broadcasting ) that is the issue , kindly check and fix it
Irshad
 Irshad
Yes, it's not working as an add-on. Kindly fix this.
Also, if a user already has 100,000 message credits and purchases an additional 200,000 credits, the total should be 300,000. However, after adding the add-on, it's updating to only 200,000. Please look into this.
Yes correct , this 2 bugs are there please fix it
user is already having 2 lakh credit consumed 1 lakh 90 thousand , if addon bought for 3 lakh credit means it should be 5 lakh , but it is showing 3 lakh ( consumed 190k ) , still 110k is pending right , that time cant able to create a broadcasting campaign for 15k , it is getting rejected
Hi,
It seems there may be an issue with broadcasting not utilizing the message credits from the add-ons. We’ll investigate and troubleshoot the problem, and if we confirm the issue, we’ll make sure to fix it.
Thank you for being with BotSailor.
Hi,
The issue should be resolved by now.
This is still not resolved, i have a plan for 200k per month credit , one user bought 300k addon , today morning 200k is done , but it is showing 500k ( balance 300k is there ), but can't send message or receive message , it took me to find this issue nearly 40 minutes, check it and fix it , before making a feature to live check it is working properly or not
note : the addon is added manually to the user
Thank you for bringing this to our attention. We’ve identified a glitch and our team is currently working on resolving it. We expect it to be fixed very soon.
Thank you for your patience.
