#2616-LOCATION NODE DOES NOT SEND DATA
Quintech
Quintech
 Quintech
Hi BS Team,
We observe that the share location node does not send location data to either Google sheet or webhook the location is only visible in the shared inbox, this is quite a problem for us as we're unable to use the location data received for further actions. It shows other data when used but the share location data is not sent.
See screenshots below for sample:
1NukXFoAAAAASUVORK5CYII=
B2RfyuUNOUoIAAAAAElFTkSuQmCC
Thank you for writing on the BotSailor forum.
It is possible to send location data to a Webhook URL; however, this cannot be done from the Start Bot flow. To achieve this, you will need to use the Outbound Webhook feature.
Step 1: Go to the Outbound Webhook section from the WhatsApp Bot Manager and click on the “Create” button.
Step 2: Provide a name for the webhook, enter the target URL, and select the trigger action as Location. Then, choose the data fields to be sent, ensuring that Location is included.
If you have any questions, please feel free to reach out to us.
xbdq1D32S40AAAAAElFTkSuQmCC
