#1915-Sequence msg not sending again 24hour
Hello team,
i created 1 sequence inside 24 hours with 3 automated reply.
Let's take example.
user say hi on whatsapp 13:00 Hour and get assigned sequence on the spot and getting message properly 1st time.
after 2nd time user run same bot using same keyword on 08:00 Hour inside 24 hours so Sequence msg not sending again.
so please fix this. if there is no such option then i request you to add an option as repeat sequence.
Sequences are designed to run once per subscriber by default. To trigger the same sequence again, you'll need to remove the current assignment and reassign the sequence. Thanks.
okay so is there any way i can restart same sequence on same keyword?
can you bring an option to set repeat sequence?
You can set by remove sequence and assign sequence both for the same keyword .
