New AI Agents Just Got More Affordable β€” Get Get 2.5x More AI Tokens More AI Tokens Pricing
#1723-Boost Reseller Income: Sell Add-ons & AI Tokens in BotSailor
πŸš€ New Revenue Opportunity Unlocked for Resellers: Sell Add-ons & AI Tokens with Your Own Pricing! We’re thrilled to introduce one of the most powerful income-generating features yet for BotSailor resellers! From now on, BotSailor resellers can create and sell their own add-ons to their customers directly from their Reseller Admin Panel. This gives you full control and flexibility to build customized upsells, boost your revenue, and add even more value to your customer base. πŸ› οΈ What’s New? βœ… Custom Add-ons for Modules Now, resellers can: Create module-based add-ons with additional features or higher usage limits. Sell premium access to specific functionalities as upgrades. Set your own pricing, bundle with your existing plans, or offer as one-time purchases. Example: Want to sell a higher limit for WooCommerce or Telegram module? Just create an add-on and upsell! πŸ€– AI Token Add-ons – Your AI Revenue Stream You asked, we delivered! Now, resellers can sell AI tokens to their usersβ€”just like we do on BotSailor.com. Here’s how it works: Buy a BotSailor AI Token package from us (available at very low wholesale prices, with unlimited validity). Create your own AI token add-ons in your panel and define how many tokens customers will get. Upsell the token packs to your customers at your preferred price. You keep the margin. This means your users can now use the AI Assistant inside your white-labeled platform using the AI tokens you provideβ€”powered by BotSailor. πŸ’‘ Why This is a Game-Changer 100% Profit Control: You decide how much you charge and how you position the add-ons. Create Premium Experiences: Offer powerful features, higher usage tiers, or AI tools to increase customer retention. Boost Your Brand Value: Provide professional, scalable upgrade options just like any top-tier SaaS business. πŸ“’ Start Selling More, Right Now! This update is already live on all BotSailor Reseller Accounts. Just head to your Reseller Admin Panel > Add-ons Section to get started. We can’t wait to see how you use this to grow your income and deliver next-level value to your users. πŸ’¬ Got questions or need help setting up your first add-on? Drop your queries in the BotSailor Reseller Forum β€” our team is here to support you every step of the way. πŸ›οΈ Ready to purchase BotSailor AI Token Packs? Click here @botsailor.com.../addon to view packages and get started.
Instead of adding new features first solve must required bug fixes... because we're losing client because of silly bugs not fixed by you in last 1+ months. @botsailor.com.../1642-credit-reset-happening-on-1st-of-every-month @botsailor.com.../1700-custom-field-not-exporting-in-download-subscriber-csv @botsailor.com.../1712-1mb-above-size-pdf-not-getting-deliver-via-bot @botsailor.com.../1615-complete-mix-template @botsailor.com.../1694-in-bot-flow-send-flow-option-shows-broadcasting @botsailor.com.../1701-shared-inbox-follow-up-notification-not-working @botsailor.com.../1539-broadcast-calculation-is-differ @botsailor.com.../1493-allow-subscriber-label-name-onetime @botsailor.com.../1459-http-api-rename-not-working @botsailor.com.../1434-adding-country-code-on-shopify-and-woocommerce-automation-doesnt-work @botsailor.com.../1396-business-hour-feature-not-working @botsailor.com.../943-emojis-not-visible-on-button @botsailor.com.../1521-panel-improvements Along with this i forgot 1 forum post but variables value not visible in live chat and while generating API so fix this. You guys taken many months and forgot to fix this we also forgot but now this is must required fix you have to provide us. this impact on our support and client. Hope you understand. I personally request you to do this week and stop any new development. definitely you talented guys will fix this bugs. thanks
Abhi
 Abhi
Mr Unick
 Mr Unick
Dear BS team Please fix these ASAP
Yes, BS Team Kindly Fix the Issues to use it more Efficiently, Additionally 2 More things are missed in above forum link @botsailor.com.../1659-start-bot-flow-webhook-not-sending-the-image @botsailor.com.../1658-custom-field-based-image-pdf-sending This 2 Issues I was Reporting you for Past 5 Months , Kindly look into those Bugs and Errors Before Moving to New Features
Yes many open bugs were not addressed still now
Irshad
 Irshad
Yes, amazing team! Bug should be fixed as a priority. Yesterday, I lost a user due to a silly bug. I hope the bugs mentioned above will be resolved as soon as possible.
Aji
 Aji
Yes team, kindly prioritize and resolve the issues mentioned above. Also, please make sure to include the following: @botsailor.com.../1704-custom-field-missing-for-date-in-whatsapp-flow @botsailor.com.../1720-request-for-manual-add-on-activation-option-for-users
mowled
 mowled
Yes, many open bugs were not addressed still now; please fix asap
@botsailor.com.../1642-credit-reset-happening-on-1st-of-every-month - (Solved) - Will update on 01-06-2025 @botsailor.com.../1700-custom-field-not-exporting-in-download-subscriber-csv (Solved) - Yes Works @botsailor.com.../1701-shared-inbox-follow-up-notification-not-working (Solved) - Yes Works @botsailor.com.../1539-broadcast-calculation-is-differ (It's perfect) - Done @botsailor.com.../1493-allow-subscriber-label-name-onetime (Solved) - Yes Works @botsailor.com.../1459-http-api-rename-not-working (Implemented) - Yes Works @botsailor.com.../943-emojis-not-visible-on-button (Solved) - Yes Works but issue is not getting sound and notification for emojis i need to refresh so pls fix @botsailor.com.../1396-business-hour-feature-not-working (Working as far we have checked.) - Yes Works @botsailor.com.../1712-1mb-above-size-pdf-not-getting-deliver-via-bot (Problem from WhatsApp end, Will check more.) - On other platform sending instantly so no META side issue @botsailor.com.../1615-complete-mix-template (Considered) - Will wait for an update @botsailor.com.../1694-in-bot-flow-send-flow-option-shows-broadcasting (Considered) - Will wait for an update @botsailor.com.../1434-adding-country-code-on-shopify-and-woocommerce-automation-doesnt-work (Will check) - Will wait for an update @botsailor.com.../1521-panel-improvements - (Ongoing as long list.) - Will wait for an update @botsailor.com.../1704-custom-field-missing-for-date-in-whatsapp-flow - ? Thanks
Yashodhan Natekar
 Yashodhan Natekar
Yes, I also lost my one user recently due to very small silly bug. Please resolve on very much priority.
Ahj
 Ahj
Instead Of Adding New Features & Selling Them As Add-on Focus On Solving Each And Every Bug First
#14
Ahj
We are continuously doing it each and everyday. And not all of them are bug but are many of them update request. And we are improving the system each and everyday. Thanks
#15
Muhammed Favas
 Muhammed Favas
Dear Team please do possible things as soon as possible
