#943-Emojis not visible on button
Hello i checked if user react emoji on buttons than not visible in live chat. Please fix or clarify this is limitation from META. Thanks
Okay, we will check this matter. Thanks
Any update on this?
Sarower Hasan
 Sarower Hasan
Thank you for your concern. We are investigating the possibility of using the emoji on buttons that are currently not visible in the meta live chat. We will keep you updated shortly. Thank you
Sarower Hasan
okay bro
We are working on this issue. We will update it to server by tomorrow. Thank you.
The problem should be solved in a while.
Along with this not getting sound notification if someone react with emoji so please look this. thanks
