#2185-FlowBuilder Not Save (BIG BUG)
UNDER-REVIEW
Hello team.
Currently the "SAVE" button of the flow builder is not working.
What's wrong:
  •   Save flows.
  •   Programming broadcast campaigns.
This is a serious mistake that cannot continue to happen, I kindly request to fix this soon.
Farhan Anjum
 Farhan Anjum
Hi there,
We apologize for the inconvenience you are experiencing with the Flow-Builder. However, when we set up a broadcasting campaign, we are able to save it successfully, and the broadcast runs smoothly. We also tested it in the normal flow builder via making bot, and it is working there we are able to save the botflow. We have attached a screenshot of our test below.
We suggest to logout and log back in and clear the cash of your browser. If you are facing the issue continuously, please open a support ticket we will check it on priority.
Farhan Anjum
Thanks for the reply. It was back up and running within a few hours.
