#2049-Broadcasting have lots of bugs, work on priority
Hello BS Team ,
till 2 -3 weeks before broadcasting works fine, but past 2 , 3 weeks its not working fine , having lots of bugs each user getting different different issues and errors , few are mentioned below , all errors are shared to your support number with screen recording , please fix all the bugs in priority rather then working on new features
  • messages are sending too slow ( taking 4-5 minute for just 50 numbers )
  • if download the report it is not showing all the column values most are empty
  • if click on resend button then its in pending only forever , not sending
  • lots of time if we schedule a campaign it is not running ( out of 10 scheduled campaigns 1 or 2 is sending , rest 8 are getting failed )
please fix it and make the broadcasting smoother
thank you
Mr Unick
 Mr Unick
I'm also facing issues with broadcast.
Please consider to fix this ASAP
Vicky Chaudhary
 Vicky Chaudhary
Same errors, Even consuming 20-40 credits for each message sent on some days.
Yes, same kind of error facing please look into it asap
Ahj
 Ahj
A Lot of error , reports are not generating
Yes too many error and BS team currently maybe not able to response our post.
Hope will get answer and resolution on saturday.
Muhammed Favas
 Muhammed Favas
Customers are reporting that the software is too buggy; they keep facing one problem after another throughout the day. We request you to prioritize a bug-free system over new developments
Dear Users,
We are currently investigating the reported issues. If any problems are identified, we will resolve them as quickly as possible.
Thank you for your patience.
The resend failed message and report download issue have been solved. We are working on the speed issue.
