#1565-Shopify Abandoned Cart not working
DEFERRED
Hello team, after an update i am creating new shopify Abandoned Cart integration but it's not creating webhooks automatically. please fix ASAP. Thanks
Amit
 Amit
I am also facing the same problem, Abandoned cart not working
Abandoned cart will not create webhook. It will work by cron job. For Shopify abandoned cart , due to shopify's new policy, make sure your account is paid plan. Thanks
Am on shopify paid plan. old integrations working i say new not working.
Okay, we will test the things to see if there is any glitch. I would recommend opening a ticket to our support desk. Thank you.
We have checked and it's working as expected. Thanks
Hello i tested on multiple development store. error is to parameter required. means phone number not received in webhook. please check and fix Abandoned Cart not working for new shopify integration. another provider's integration working means bug is in BS. i resolved order notification issue.
Hi, Thank you for your reply. For now, we cannot confirm whether this issue is on our end, as we still need more context to determine the cause. How is Official WhatsApp (Means my whitelabel platform) integrated with your store? Can you please provide the replication steps for the issue, including screenshots or recordings (preferably) so we can compare the expected and actual behavior when you perform the same action in different stores? This will help us better understand the issue and resolve it effectively. Best Regards, Francis | Shopify Developer Support
Any update
