I'm confused that what is the difference between Connect WhatsApp Business (Recommended) One Click Business Integration Connect WhatsApp Business (Alternative) Connect your WhatsApp account Can anyone please help me to understand.
#1230-Difference between connections
Muhammad Rehan
Muhammad Rehan
in 1st method your customer don't need to create an app they can easily onboard number within 5 mins (make sure you're a tech provider than only possible) in 2nd method your every client have to signup as META developer and create an app than onboard number and will take around 30-45 mins. so use 1st method. if you have any query regarding 1st method (Tech provider) than Abhinandan Jhamb is a best person to help you. Thanks
Muhammad Rehan
Dm me i will help you to setup all things @wa.link.../i5gmz1
There are different ways to connect your WhatsApp account to BotSailor. The embedded sign-up method is quick and easy, requiring just a few clicks to connect your account. The other option involves creating an app on Facebook Business, adding your WhatsApp number, and then connecting using the business number and secret key. If you are using our White Label Agency package, you’ll need to create an app and connect it to BotSailor to enable your users to use the embedded sign-up feature. If you have any questions, feel free to contact us via WhatsApp or support tickets. Thank you, Team BotSailor"
