#2710-Feature Request: Custom Webhook Flow Builder
The Dreamaholics
The Dreamaholics
 The Dreamaholics
Feature Description:
Users should be able to create custom webhook flows based on their business requirements. This feature will help them connect external applications, send and receive data, trigger API requests, and automate workflows without relying on fixed webhook configurations.
Key Requirements:
  1. Custom Webhook Creation: Allow users to create and configure their own webhook flows.
  2. API Integration: Support external API requests, including GET, POST, PUT, and DELETE methods.
  3. Dynamic Data Mapping: Allow users to map incoming and outgoing data dynamically.
  4. Custom Triggers: Trigger webhook flows based on specific events or conditions.
  5. Request & Response Handling: Allow users to process API responses and use the returned data in subsequent workflow steps.
  6. Conditional Logic: Support conditions to control the flow based on API responses or received data.
  7. Error Handling: Provide error logs, response status codes, and retry options for failed requests.
Expected Benefits:
  • Greater flexibility in integrating third-party applications.
  • Easier automation of complex business processes.
  • Reduced dependency on external automation tools.
  • Better control over API requests, webhook triggers, and data processing.
Expected Outcome:
A flexible custom webhook flow builder that enables users to create end-to-end automations using webhooks and APIs according to their specific business requirements.
