#921-Share Your API Integration Needs: Help Us Build Tailored Tutorials
💡 Calling All BotSailor Users! 💡 We’ve recently launched HTTP API integration in our chatbot builder, and we’re excited to help you connect your chatbots with the external platforms you use. To make this even more useful, we want to create tutorials and guides based on real-world examples—and we need your help! 🌍 👉 Tell us which APIs you’d like to integrate! Whether it’s CRM, e-commerce platforms, social media, or anything else, we’d love to hear about the specific APIs you’re using or need help connecting. Your feedback will help us provide step-by-step instructions and tailored examples that address your needs. Looking forward to your responses! 🙌
Sure allow sometime to share
i want to fetch data from Googlesheet into Chatbot flow for eg. if user enter keyword on waba - router than on specific keyword bot send message from Googlesheet rows i entered. this msg on googlesheet will be change every week or daily. so same i will create keyword based bot and msg content can be change by user. if this achieve we can give freedom user to change msg content from google sheet will be very helpful and gamechanger for BS. Thanks
Is there any way to send catalog order data in woocommerce or shopify?
Yes you can using webhook
Do You Have Any Tutorial Video?
Adrián Brito
 Adrián Brito
Shopify, Meta, Make.com API's would be amazing. Imagine connect an external automation such as Make with BotSailor, that would be sick!!
