Dear BotSailor Support Team,
I am reporting a bug related to the management of failed webhook messages in the workflow report.
Issue Description:
In the webhook section, when messages fail to deliver (as shown in the attached report with Error Code: 131049), there is no option to resend individual failed messages. Currently, the only available option is "Send to Failed Webhook All," which does not work as expected and returns a "zero webhook found" response.
Steps to Reproduce:
- Navigate to the workflow report where failed webhooks are listed.
- Observe the absence of a "Resend" button next to individual failed entries.
- Attempt to use the "Send to Failed Webhook All" option.
- Note the error response: "Zero webhook found."
Expected Behavior:
- Each failed webhook message should have an individual "Resend" button or option.
- The "Send to Failed Webhook All" function should successfully identify and resend all failed webhooks.
Impact:
This bug prevents efficient troubleshooting and resolution of failed webhook deliveries, leading to potential disruptions in workflow automation and user engagement.
