the message template cant be deleted
#2419-i need help and no one answer me
Event icon
Event icon
We sincerely apologize for the delayed response.
This issue is related to the WhatsApp Cloud API and occurs only with WhatsApp numbers that are connected manually. Numbers connected through the Embedded Signup process are not affected.
We have identified a solution to this issue. The app needs to be reassigned to the system user, after which a new access token must be generated and the account reconnected to BotSailor. Once this process is completed, the issue will be resolved, and you will be able to delete WhatsApp message templates as expected.
We have recorded a video guide to help you clearly understand the required steps. Please watch the video below to see how to resolve the issue.
Thank you for your patience and cooperation.
