#2000-Custom field not save from Flow Form
Hello team,
i noticed assigned custom field in flow form fields not getting saved.
please fix.
Farhan Anjum
 Farhan Anjum
Hi,
Thank you for reporting the issue.
We’ve tested the WhatsApp flow on our end, and it appears that the data is being saved correctly into the custom fields. You can check our test recording here:
@sendpro.cloud.../download.php
To assist you better, we kindly request you to share a short screen recording from your side showing the issue. This will help us understand the exact scenario and guide you accordingly.
Looking forward to your response.
Regards,
Support Team
Yes now seems working fine as expected.
