#1886-problem with sequences
DEFERRED
Hello.
When you add a sequence to a broadcast, the sequence is created and there's no way to delete it. It remains in the broadcast flow and can't be edited later. If I duplicate broadcast campaigns to send quickly, all the sequences are duplicated.
Please provide an option to delete sequences directly.
Hello Admin,
We apologize for any inconvenience. Currently, it's not possible to delete a sequence independently.
However, we appreciate your suggestion to add this functionality and will consider it for future updates.
Thank you for being with us.
I had to delete the duplicate broadcast campaigns, and that way the sequences were deleted. But in a way, I think they should be separate functions. Like: creating the sequence and the entire flow.
Then simply assigning it to a botreply when I want to use it without further ado. Well, this can already be done. But the creation of the sequence itself always goes hand in hand with a botreply or a specific flow.
