#1529-Shopify WebHook API Callback is Removing tags instead of Adding tags
Adrián Brito
Adrián Brito
 Adrián Brito
The problem is that when a customer clicks on the confirm order button, in the WhatsApp Webhook (in-bound) Workflow I have configured Callback APIs (Trigger a third-party API based on webhook data after a WhatsApp message button is clicked) which is DELETING the previous tags that the order had in Shopify and is causing us to lose information. I have contacted support several times and they are not giving me a solution. What I need is to ADD a tag, not to REPLACE all the tags in the order with the one I define. I am sure it is not that hard to solve this issue. I just renewed the plan and paid $ 162.00 USD...
Adrián Brito
I am going to check the matter for your as soon as possible and fix it with priority. Thanks
Yes, I found the reason why it's replacing old tags. We will tweak it very soon and update. Thanks for your patience. Best Regards Konok
We have provided an update by fixing it. We are testing now. Thanks
Update us once you apply patch.
It has been fixed. Thanks
