#1945-Give sequence option on Interactive
Hello team,
can you give us an option to subscribe sequence on interactive.. along with this not limited sequence to button element but try to bring on every elements so it will be very powerful automation.
Sequences can be assigned to interactive buttons and lists within our Chatbot platform. If you'd like to extend automation to other elements, please specify which ones, and we’ll assist accordingly. Thanks.
Hi
create a module that inserts a sequence into the flow.
This could also be replicated with inserting labels and other actions.
sorry not understand. please describe more on this concept.
Create a Separate Node for sequence -> so we can drag and drop to configure the sequence , for example , let's say i want to create and assign sequence when received message, but currently i needs to create that sequence separately in another bot reply and want to assign right , in the new bot reply also i need to add a interactive then button then only i can create a sequence which is a too lengthy process , most customers not understanding why new bot , button and then sequence then assigning here like that asking , so you can simplify the process by adding a separate node like text , image , video ...
A module that allows you to insert sequences, add tags, or more actions simply by adding them to the flow without the need for an interactive interface.
Yes you are right this will help everyone is not technical
WhatsApp
 WhatsApp
This is extremely useful, is this implemented?
yes as a seperate module it will be easy for users to add
