#2714-AI-Powered Flow Generation
Abubakr Muhammad
Abubakr Muhammad
 Abubakr Muhammad
Hello BotSailor Team, I would like to suggest a very important feature that could significantly improve the Bot Flow Builder experience: AI-Powered Flow Generation from Natural Language Prompts. The idea is to allow users to create complete, ready-to-use automation flows simply by describing what they want in natural language, directly inside the Bot Flow Builder.
How it should work: 1. The user clicks a new "Generate Flow with AI" button inside the Flow Builder. 2. A prompt window opens where the user describes the automation they want to build. 3. The AI analyzes the requirements and automatically generates the entire flow, including nodes, connections, conditions, actions, and logical branches. 4. The generated flow appears visually inside the Flow Builder, ready for review, editing, testing, and publishing.
Suggested Advanced Capabilities: • Generate complete multi-step automation flows from simple text descriptions. • Automatically select and configure the appropriate nodes. • Create conditional logic, branching, delays, and customer response handling. • Support generating flows in multiple languages. • Allow users to refine existing flows through AI instructions, such as "Add a follow-up after 24 hours" or "Add a condition for customers interested in pricing." • Detect missing information and ask relevant questions before generating the flow. • Validate the generated flow and highlight any missing configurations or potential errors. • Allow AI to modify specific sections of an existing flow without rebuilding everything.
Example Prompt: "Create a WhatsApp chatbot for a real estate company that welcomes customers, asks whether they want to buy or rent, collects their budget and preferred location, saves their information, assigns qualified leads to a sales agent, and sends a follow-up if they don't respond within 24 hours." The AI should automatically generate the complete flow visually, with all necessary nodes and connections.
Why This Feature Matters: This would dramatically reduce the time and technical knowledge required to build complex automations.
Instead of manually creating every node, users could build sophisticated automation workflows in minutes using simple natural language.
I believe AI-Powered Flow Generation could become one of BotSailor's most powerful and competitive features.
Please consider prioritizing this feature in your development roadmap.
Hi,
Your requested feature is implemented, please have a look and share your feedback.
BotSailor Team
