#1072-Resend campaign on Fail Delivery subscribers
Faizal
Faizal
 Faizal
Hi, Please add a feature to resend those failed message happened. Today I sent message in which 80% going failed. If we have a option resend those failed subscriber again then it will be helpful. I see some other companies has the same feature to resend msz after failure Ref - @prnt.sc.../V1N-m8GAxprY
Thanks for your suggestion. Okay , we have already have plan for it. However WhatsApp doesn't deliver the message due to some reason. You can check the failed reason by hovering moused on the failed field. And I have strong doubt, If we resend it will deliver or not. However we will provide this functionality. Thanks
Faizal
Add Label on failed delivery and resend broadcasting by applying label filter. will be useful am using this already.
Faizal
 Faizal
Yes it deliver, not the 100% but few will trigger. I use that feature in AISensy and it works.
Faizal
 Faizal
That's great idea, but if we have a option for it then it will save a time a lot.
Faizal
We have already have this option to assign label to subscribers who message deliver failed. @prnt.sc.../MvNdEvlo0QEI please check. Thanks Konok
Faizal
I have already assigned our team member to implement this. We will release the update after this weekend. Thanks Konok
Faizal
 Faizal
Thank you sir
We will release the functionality by tomorrow. Thanks
We have provided option to resend delivery failed message in WhatsApp Broadcasting and updated to server. Cheers :) Thanks Konok
Faizal
 Faizal
Amazing, just using that feature. It work great. kudos to entire team
Faizal
Thanks that it's beneficial for you. Regards
