Hello BotSailor Technical Support Team,
We are using BotSailor for WhatsApp appointment booking notifications.
Our existing integration details:
- Backend: Node.js / Express hosted on Render
- Webhook URL: @guruvidya-backend.onrender.com.../botsailor
- Configuration: Automation → Outbound Actions → Webhook Workflows
- Five existing outbound webhook workflows
- POSTBACK and POSTBACK ID enabled in one workflow
Our current booking notification workflows are working. We are implementing appointment reminder button-click tracking and need clarification before enabling it.
Please confirm the following:
- Does BotSailor authenticate outbound webhook requests using a cryptographic signature? If yes, what are the exact HTTP header, algorithm, raw-body signing procedure, and secret configuration? If not, what secure authentication method do you recommend?
- What is the actual JSON payload for a WhatsApp template Quick Reply click? Please identify the fields for button title, postback ID, sender, incoming event ID, original outgoing message/context ID, account ID, and timestamp.
- Our configured Quick Reply values include
SjLv2QCfcOJmKRK,appointment-reschedule, andappointment-cancel. Which fields carry these values? - How can an incoming button click be reliably matched to the exact outgoing WhatsApp template message?
- Can the same webhook event be retried? Which unique event identifier should be used for deduplication?
- Can this be implemented through our existing webhook workflows without changing working booking notifications?
Please provide documentation or a redacted sample HTTP request with headers and JSON body.
This is a technical clarification request only. Please do not modify our configuration, trigger messages, or enable automation.
Thank you,
