#2383-Need Feature: Business Off-Hour Chatbot Flow Setup
Currently, we can set our business “Off-Hour” timing, but there is no option to build a dedicated Off-Hour Chatbot Flow.
We need a system where:
  • When customers message outside business hours
  • Trigger a custom message flow or chatbot
We've been waiting for this feature for a long time; customers have been asking for it.
This will be very help full already requested and explain in separate thread but no response so far
We are considering introducing a Business Off-Hours Bot feature. This will allow you to configure a bot that operates exclusively during non-business hours.
We have listened to your request and successfully implemented the feature. You can now assign a dedicated bot for business off-hours.
To use this feature, go to Business Hour Settings, enable the Business Off-Hour Bot, and select your preferred bot for handling messages during off-hours.
For your convenience, a screenshot is attached.
Thank you for your patience and for being with BotSailor.
O7L+I+i0FAAAAAElFTkSuQmCC
Thank you Kamrul Hasan for the feature update we can see the Business Off-Hour Bot reply option but there is no option to set a Out of working hours” bot option.
Excellent. Please remember to integrate the translations.
Dear user,
Business off hours and out of working hours are same in BotSailor. There is no separate out of working hours.
Hi  Kamrul Hasan thanks for responding need some clarification if i want to set the "Out of working hours bot" where should i choose it. As i can understand "Enable Special bot" will work during the working hours which will select under the "Select Bot flow" but how to set the "Out of working hours bot"
9k=
This is the Business off our / out of working hour bot.
