#2029-Sequence not sending
Sequence not sending for day1, day2 messages , while connected with live chat support , they said
"The problem may have arisen due to your campaign update yesterday. Please note that if you update a sequence campaign, it will not function correctly. We will investigate the sequence issue further and provide you with an update tomorrow."
Please fix it soon as possible
Have you updated your campaign ? And set different day for the campaign ? Is newly assigned subscribers are triggering or not ?
If newly assigned subscribers are not triggering let me know.
newly assigned subscriber also not triggered
We are checking the matter. Sorry for this inconvenience.
We have found an issue and solve the problem. It should work from now. If you still face issue, let me know.
Konok
Ok, i will check and update you , does the http api on sequence is fixed ? @botsailor.com.../2002-sequence-builder-http-api-is-not-working this issue
Sequence messages are NOT working, THEY DO NOT SEND ANYTHING and we lose CUSTOMERS.
It has been fixed.
Konok
