#1650-Interval between marketing campaign messages
CLOSED
Hello team I would like to request the interval between marketing messages feature for WhatsApp. I previously sent 400 messages and was blocked, as these are sent immediately and without any pause. I think it would be a good idea to be able to set an interval between messages to avoid account blocks. I look forward to hearing from you.
Thank you for your suggestion and for reaching out regarding the message interval feature. We understand your concern about account blocks and the idea of adding a delay between WhatsApp marketing messages. Technically, we can implement an optional delay between messages. However, it's important to note that sending messages quickly isn't usually the main reason for account blocks. In most cases, blocks happen when recipients mark messages as spam, report the sender, or block the number. WhatsApp monitors user feedback closely, and high negative response rates can trigger restrictions, regardless of how fast or slow the messages are sent. That said, we’ll still consider your request as a possible enhancement to give users more control. In the meantime, we strongly recommend: Sending messages only to opted-in users, Using high-quality, relevant template messages, Regularly rotating content and phone numbers if possible. Thanks again for your feedback — it really helps us improve. Best regards,
I understand. Thanks for the reply.
