#1644-Remove Label
Kiss Andras
Kiss Andras
 Kiss Andras
Add ability to remove label via API. If some of my contacts change and I need to assign different label then I cannot do it via the interface or the API. This is a much needed feature, since you cannot manage your contact list effectively without!
Add this in webhook also option to remove label
Thank you for your valuable feedback and for highlighting the need to remove labels via the API. We completely understand how important this feature is for effectively managing your contact list, especially when label assignments change over time. The good news is that we do have plans to implement this functionality in a future update. Once available, it will allow for better flexibility and automation when handling your contacts through the API. We appreciate your patience and support as we continue to improve the platform. Best regards,
We have implemented remove label of subscribers API for WhatsApp, Will release it by tomorrow. Thanks
Label remove API for WhatsApp Subscribers has been released. Thanks
