#1540-maximum token limit option
hi , while sending a chatgpt ai reply want to restrict maximum token per message, kindly provide that, the charges are getting huge , as its replying like a article for every message
For this you can simply tweak the prompt of your AI Assistant Training data. In the prompt you can add something like this in the end "Provide answer in short as much possible." . Then AI will reply with short answer. Maximum token limit may not work as it works with both work with input token and output token. Thanks
I hope you already provided this max token use per message option in chatpion
Yes, Because ChatPion AI is very simple and straight forward. Anyway we will provide option in future also. Thanks
Thank you
