#2690-AI Token Consumption Alert
The Dreamaholics
The Dreamaholics
 The Dreamaholics
Requirement
Add a feature to automatically notify users when their AI token consumption reaches a predefined threshold.
Expected Behavior
Provide an option to create a notification template with a dynamic variable for the current AI token consumption percentage.
For example:
  • Admin creates an alert template.
  • The template can contain a variable such as {{token_usage_percentage}}.
  • The system continuously monitors AI token consumption.
  • When usage reaches 80%, the system automatically triggers the configured WhatsApp template message to the user.
Example Template
"⚠️ Your AI token usage has reached {{token_usage_percentage}}%. Please consider upgrading or adding more tokens to continue using AI services without interruption."
When usage reaches 80%, the user receives:
"⚠️ Your AI token usage has reached 80%. Please consider upgrading or adding more tokens to continue using AI services without interruption."
Suggested Configuration
The admin should be able to configure:
  • Alert threshold (e.g., 80%, 90%, 95%)
  • WhatsApp template
  • Dynamic token usage variable
  • Recipient/user
  • Alert frequency
Additional Requirement
The system should avoid sending the same alert repeatedly for the same threshold.
For example:
  • At 80% → Send alert once
  • At 90% → Send alert once
  • At 95% → Send alert once
This will help users understand their remaining AI token balance and take action before reaching the token limit.
