#2507-Add custom/label fields to incoming webhook
Muhammad Annas
Muhammad Annas
 Muhammad Annas
Hi Botsailor Team,
I’m using the Incoming Message Webhook to receive every real-time messages from connected channels. Currently, the payload includes subscriber ID, timestamp, message content, and type.
For my workflows, I also need customer custom fields and labels included in the same webhook JSON.
Can you:
  1. Enable these additional fields in the incoming message webhook payload?
  2. Provide the variable names (e.g., label, custom fields) if I need to adjust the configuration myself?
Please let me know if this is possible and how I can implement it.
Thanks!
Thanks for the suggestion. We’re reviewing your request to include customer custom fields and labels in the Incoming Message Webhook payload and will work to implement it as soon as possible. We’ll update you with progress.
Muhammad Annas
 Muhammad Annas
Thank you for considering this. I am looking forward to the next steps.
Mamuduzzaman Ronok
 Mamuduzzaman Ronok
Feature update: We’ve added customer custom fields and labels to the Incoming Message Webhook payload. Please check on your end and confirm if this meets your needs.
Mamuduzzaman Ronok
Where i can find this update??
also please implement custom field mapping for Webhook (in-bound) Workflow.
Muhammad Annas
 Muhammad Annas
Mamuduzzaman Ronok
Yes i have checked. Its working. Thanks a lot.
i tested with custom field in template then send data to webhook but not storing in custom fields.
