#1824-Make Shared inbox fonts like Old Livechat
Hello team, now i see you're adding features in Shared inbox so very soon Old live chat you will discontinue. So i request you to make shared inbox UI properly as old live chat like Fonts, color, right side pane sticky and everything looks preety good as old livechat so please work on this. thanks
Yes team, provide some options to change css also
Mr Unick
 Mr Unick
Yes, either provide us the option to make it same as old live chat or just set it as default
Yes, the WhatsApp Live Chat UI is good with 3 columns ( we can easily view the labels, sequence and custom field values what added , bot reply is enabled or not and all ) but shared inbox it is unnecessory step we need to click another one icon to view, also the UI of Shared Inbox is not giving the good feel of using whatsapp live chat, kindly bring the shared inbox similar to the panel , it is looking that seperate software not compatible with the software UI , while i ask to my exisiting customers about which is best suits , morethen 80% are saying whatsapp livechat is good and easy...
Thank you for your feedback. We are actively considering your suggestions and will work on implementing UI improvements for the shared inbox to match the WhatsApp Chatbot's existing experience.
Thanks for considering
We have made initial updates to improve the shared inbox UI, including font adjustments. Further enhancements will be rolled out gradually. We will update you in a dedicated thread regarding ongoing improvements. Thanks.
Yes i see fonts look good but still canned response having much space and send flow, template search not works
Hi friend. The Telegram bots still aren't showing up in the shared chat so I can send them.
We are working on them too. Thanks for your feedback.
Konok
Fixing it soon.
Regards
Konok
