#1693-improvements in Shared Inbox
Hello Team Suggested Improvements for Shared Inbox Automatic Layout Adjustment When resizing the window on desktop, the content should adapt instantly without needing to reload the page. Dark Mode on Mobile Ensure the dark theme is applied correctly inside each chat when the device is in night mode. Configurable “Typing” Indicator Add a setting to enable or disable the “typing…” status for both users and the AI assistant. “Recording Audio” Indicator Display “Recording audio…” while the user is recording a voice message. Performance Optimization Improve loading speed and overall responsiveness of the tool. Email Sending from Chat If the subscriber’s email is available, provide an action to send them an email directly from the chat options. Desktop App for Shared Inbox Develop an installable Shared Inbox application (Windows/macOS) that launches faster and delivers a smoother experience than the web version. Thanks
Thanks for your all suggestion. We will consider them one by one gradually. However - Configurable “Typing” Indicator Add a setting to enable or disable the “typing…” status for both users and the AI assistant. This option is already available. You can enable disable typing indicator from 3 different places and control for 3 different purposes. Like for agent reply, bot reply and also AI assistant reply. Read details here @botsailor.com.../new-typing-indicators-in-whatsapp-cloud-api Thanks
Currently the Typing feature works even if it is not enabled and the bot is paused.
Can you please make a screenshot/short video by showing when typing indicator is showing even it's disabled. Thanks
