#1341-Folder for each bot flows
Ahammed Junaid
Ahammed Junaid
 Ahammed Junaid
Is it possible to create any group/folder to keep related bot reply flows together?
Sarower Hasan
 Sarower Hasan
Thank you for opening this thread! Could you please provide more details about your request? For example, are you looking to create separate groups for each chatbot? Please note that we currently have section such as the Bot Reply section, Chat Widget section, Sequence, Input Flow, and WhatsApp flow and so on If you could describe your needs in more detail, it would help us better understand and provide an appropriate update. We’re here to assist you! Thank you
Ahammed Junaid
 Ahammed Junaid
Sarower Hasan
Yes.. looking for separate group for different set of bot flows. Suppose if i have three different flows. These three will be having different customer bases and different style of flow. So if there is an option for folder like customer_1, i can add all the flows related to him under that folder. So it wont mix up with others. The same way if we can use the custom variable too. If i use a custome variable, for example #location# inside the particular folder, it need not to be visible when i work inside the second folder customer_2.
Danial durai
 Danial durai
Yes, For Me also having 100+ Chatbots but can't able to view and manage it , if you provide a folder structure it would be great to organize the bots , also provide a option to enable disbale bots feautre which having in chatpion ( bot keyword settings , we can turn off particular bot right , like that )
