#2357-Dashboard Interface Enhancement Suggestion
The dashboard layout is not fully device friendly. It affects mobile and tablet use. Is there any plan to improve the interface and add a color update option for white label users. This will support better daily operations.
There is also a limitation in the Business Configuration section. The panel only allows a single start time and end time. Many businesses operate with different hours on different days. There should be an option to set multiple time ranges or day wise hours. This will make the configuration more accurate and practical.
I want to add one more suggestion to my previous feature request.
A no-code visual flow builder would help users create and manage bots through a simple drag and drop interface where user can build multiple bots and can use as per the requirement. This type of builder increases usability for non technical users and speeds up bot creation for business teams. It also supports clearer logic management and easier updates.
Please consider adding this feature, since it will improve workflow for business partners and reduce dependency on manual configuration.
