#2136-Encrypt & Mask AI Key on Dashboard
The Dreamaholic
CONSIDERED
The Dreamaholic
 The Dreamaholic
The AI key should be securely encrypted instead of being displayed in plain text on the dashboard. Currently, the key is directly visible and can be easily copied or misused, which poses a security risk. The system must ensure that the AI key is stored in an encrypted format in the database and only a masked version (e.g., sk-xxxxxxx...) is shown on the dashboard. Access to view or copy the full key should be restricted to authorized users only, with proper permissions and confirmation steps. This will help protect sensitive credentials, prevent unauthorized use, and maintain compliance with security best practices.
This should be applied to Google Key, GPT, and any tokens as they are all visible.
The Dreamaholic
 The Dreamaholic
Any updates on this request? It has been in considered status for the last month, but we haven’t received any further updates. Could you please let us know the current progress or expected timeline?
The Dreamaholics
 The Dreamaholics
Hello Team,
This request has been in Considered status for quite some time. Could you please share an update on the current progress or the expected timeline for implementation?
This is a critical security requirement as the AI keys and tokens are currently visible in plain text on the dashboard. We would appreciate any update you can provide.
The Dreamaholics
 The Dreamaholics
HI Team,
