#1855-Send Incoming Message to Webhook URL
The webhook is sending only below infomation, add the waba number the message received. I have 5 numbers and using single webhook to read all message, it confusing to which number message received
{"first_name":"Sky Free","chat_id":"9194433","user_message":"56464", from:"the number user message " }
We will update the webhook to include the WhatsApp number the message was received from, helping you identify messages across multiple numbers. Thank you.
The webhook will now include the WhatsApp number the message was received from, helping you identify messages across multiple numbers. Just make sure to save the flow or webhook once again.
Thanks for this update.
will be helpful for us
Kishore M
 Kishore M
This is not working. We are getting the same response as earlier.
Kishore M
As said, please just save the webhook workflow url once for existing flow. And for new flow it will work normally.
Kishore M
 Kishore M
Tried but not working. Please check and let us know. 1748955193_1000279927.png
Have you edited the flow and save again ? If yes and still not works, then please contact our support desk please by creating support ticket , so we can check the issue.
Kishore M
I have found a small issue and fixed it. It should work now hopefully.
Kishore M
 Kishore M
Thank you so much.. now it is working as expected.
