#1829-API for adding/removing Sequence
WhatsApp
WhatsApp
 WhatsApp
...editor did not show, posted formatted request below.
WhatsApp
 WhatsApp
WhatsApp
WhatsApp
 WhatsApp
Hello Team,
I believe this is a less time-consuming task. Kindly consider implementing it quickly.
We do not have any API for this purpose. Kindly provide.
Suggestion:
You can give the ability to update subscribers to edit all the subscribers details which are currently editable from the web-panel right now. This will give more robust control.
For example: message_sequence_id (comma separated) you can overwrite if coming empty or multiple and if not coming at in in the API request, keep it as it was.
Additional:
You need to show sequence ID in sequence list under bot manager
WhatsApp
Thank you for your suggestion. We are currently evaluating its feasibility for future implementation.
We have provided API endpoints for assigning and removing sequences, enhancing your chatbot management capabilities. Thanks.
