Up to 60% OFF with Recurring Discounts on Premium Upgrades & Whitelabel Flex Up to 60% OFF on Premium Upgrade & Whitelabel 00: 00: 00: 00 Claim
#1778-Add custom field filter option in broadcast
In the broadcast feature, we currently have the option to include or exclude label IDs. Similarly, add an option to send messages based on a custom field. Provide a dropdown to select the desired custom field. Then, display an input box to enter the value for that custom field. The message should only be sent to contacts whose selected custom field matches the entered value.
It will enhance broadcasting feature. BS team please take a look and consider. thanks
Mr Unick
 Mr Unick
This will make broadcast much better, please consider
Mr Unick
Yes, Good suggestion. We will provide more filtering option in broadcasting very soon. Thanks
Muhammed Favas
 Muhammed Favas
Highly required one, Please consider
Muhammed Favas
Our development team has already been assigned to work on this implementation.
Thank you, please also display what filter applied after broadcast sent in the summary so it wil be easy for us to track
Thank you for your patience. We are actively working to enable filters and targeted audience details in reports, which will be available soon.
We have enhanced the broadcast feature by introducing filters such as custom field values and subscriber country, along with the option to assign labels after sending. Additionally, broadcast campaign details are now visible in reports. Currently, country and custom field filters are single selections, but we plan to support multiple options in future updates.
WhatsApp Broadcast Subscriber Targeting:
WhatsApp Broadcast Report :
Really nice update.
You're welcome! If you have any further questions about our WhatsApp Chatbot or broadcasting features, feel free to ask.
In report please check target audience lable i selected for include is also shows in exclude so please fix it @prnt.sc.../8R3hpdUxbMdZ thanks
It should be solved.
Seems resolved.
