#1744-Sidebar Option Not Included in CSS Customization Settings
abdullah
Hello team, While working on customizing the appearance using CSS, I noticed that the specific option in the sidebar "Settings" is not included or does not reflect any changes through the CSS customization panel. Please check if this option can be added to the customizable elements, or advise if there's an alternative method to target it via custom CSS. Thank you for your continued efforts and the great work you’re doing.
Related Threads
Default Templates White-Label Accounts
Tarek -
Auto Exit from Sequence After Completion
Tarek -
chatwoot as message inbox
Admin. -
Endpoint of the pause/resume IA & Botreply
Admin. -
Payment Failure / WABA Disabled Alerts
Tarek -
Show payment method added or not for WABA
Sky Free -
Template Restriction API (Wallet Enforcement)
Maxs -
10
i have issue with User Permission
hassan ali -
12
Request to Add Multiple Working Hour Options
PrimeX -
Google Meet and Google Calendar integration is required
Support Team -
Agent-wise Assigned Lead Count Visibility
The Dreamaholics -
Request To Follow + Follow To DM (ManyChat)
GG Tech
