#2530-Simple Broadcast Campaign Creation
Irshad
Irshad
 Irshad
We request a simple broadcast campaign creation option instead of redirecting users to the Flow Builder. For basic broadcast campaigns, the Flow Builder nodes are not required and add unnecessary complexity.
A dedicated, straightforward broadcast creation form would improve usability, reduce setup time, and provide a better experience for users who only want to send simple broadcasts.
Irshad
Yes because every user says why you have used flow builder for broadcasting.. instead of this allows us simple broadcasting option.
hope BS team will consider.
Dear Users,
There are two types of broadcasting. When sending broadcasts within the 24-hour window, you must use the Flow Builder and place the message inside the “Visual Flow Builder” within the Broadcasting section.
We've added a simple broadcasting option in the mobile for basic campaigns, enabling straightforward sends without using Flow Builder.
Yes i checked very good option bring for desktop also and i noticed delay options seems good to prevent block.
