#2117-Improve sequence assignment
Hello
Please provide the option in sequences to automatically unassign them once all scheduled deliveries are completed.
Why?
The sequence can only be assigned once. But what if I need to assign it multiple times in the future if it's already assigned? It doesn't work. This causes problems for some users and could also cause issues for those who only want to assign it once. Therefore, it would be advisable to enable or disable automatic unassignment of a sequence so that, if I need to assign it again, it's possible.
Thank you for your suggestions. We are actively considering your request for the option to automatically unassign sequences after scheduled deliveries are completed in our next update. Regards.
Yes really nice suggestion and it will help us
We have implemented the feature. You can now schedule the same sequence for the same subscribers multiple times by triggering the bot flow again after the sequence has been fully completed (i.e., after all messages in the sequence have been delivered).
To use this, simply enable the newly added option:
"Allow re-entry only after completion — subscribers won't be added again while the sequence is running. If triggered after completion, the sequence will restart from the beginning."
This option is available within the sequence settings. I have attached a screenshot for better understanding.
If you have any questions, please don’t hesitate to ask.
Thank you for your patience and for being with BotSailor.
MwAAAABJRU5ErkJggg==
