#1767-Send All Incoming Messages to Webhook URL
Laksh Ahuja
Laksh Ahuja
 Laksh Ahuja
t would be great if you can add an option to send all incoming messages to a webhook URL. Here’s what we need: Every message we receive (text, image, etc.) should be sent to our webhook URL. It should work without using any postback buttons or input flows. The data sent to the webhook can include message text, subs ID, time, and message type. This will help us manage replies and workflows from our own system in real-time. Please let us know if this is possible or if it’s something you can add soon.
Laksh Ahuja
Yes this will be helpful
Laksh Ahuja
Yes, it will allow us to create external system like app or for notification
Ahj
 Ahj
Much needed please consider this
Mr Unick
 Mr Unick
Please consider
For each and every incoming message calling External Webhook or API is actually big server resource consuming matter. However we will think about it how we can manage it. Thanks
Provide a way to read the incoming messages from existing webhook url
Ahj
 Ahj
Dear bs This is Something Important Please Look Into This
We have provided the settings of central webhook for all incoming message in Bot Configuration. It's a module based feature. So you can enable or disable the feature for your end users by your choice. Webhook call will cost 1 credit. Currently it's available for our PPU White Label reseller. Thanks
Muhammed Favas
 Muhammed Favas
Thank you
i checked text and image works. but interactive not shows user which quick reply or list button clicked. so please check and fix. along with this can you give an option to stop forward webhook on specific bot because when user start chat with bot there is an already option to forward webhooks. please do work around. thanks
Okay, I am checking it. Thanks
#14
The issue has been resolved. The update will be deployed to production later today. Thank you!
#15
WhatsApp
 WhatsApp
When will this be available for other whitelable resellers?
