#1017-CTA Button with Image/video.
Faizal
UNDER-REVIEW
Faizal
 Faizal
Please allow you bot to send multiple msz at first response, as of now it only trigger one response. I want to trigger two messages on a trigger of a keyword. But failed to do so.. only one msz option there
Faizal
 Faizal
I think you didn't understand my question. please check screenshot @prnt.sc.../xvGq30ppL10u On a First msz response of particular keyword I want to show two messages, already contact support person he said that feature is not available @prnt.sc.../FCvevtmgGkWy
Sarower Hasan
 Sarower Hasan
Sorry for the misunderstanding. You can set one component at a time with the start bot flow. you can't add two components with the start bot flow. if you want to set multiple messages you have to set one component by another otherwise you need to create multiple bots if you want to add. hope this clarifies the issue. Thank you
Faizal
 Faizal
Sir can you take it a feature request... because multi msz is very common.
Faizal
You actually misunderstand. Sorry for these not to make sure how it can be already. You can actually send as much message you want for the first time or anytime you want. In your screenshot, First you have added a message with button. Now in the first element, you can see Next Node. Just add another element with that first element from Next . It will send as much message you will set by next to next. let me know if you can make it work. Otherwise I will make a video how you can do that. Thanks Konok
Faizal
 Faizal
Yes I got it now. One more question, can we add image or video on CTA button url. I see only text option. @prnt.sc.../xRDb-OqQEe9e Also CTA Button has no phone number option
Sarower Hasan
 Sarower Hasan
We’re glad you understand. Thank you for your questions. Apologize, you cannot add an image or video to the CTA button URL, as it is designed solely for URLs. If you want to include images or videos, please use the interactive component or a separate image or video component. Sharing your thoughts on the CTA button URL will help us provide a better solution. Thank you
Faizal
 Faizal
We can use interactive component but there we can't connect CTA button with interactive component it display incompatible connection , we have to choose simple button and In that simple button we can't add link we have to create further a text message component for it on button replies. Reference - @prnt.sc.../SZ_seAmnWYL_
Faizal
CTA URL button element should be used as an independent reply, it can not be added as a Interactive button. Thanks
Faizal
 Faizal
Yes that what I m explaining... you can take this as feature request where we can add CTA Button having image/video. As of now CTA button has just text option
Faizal
 Faizal
Any update on this sir??
