#747-input flow multi save
MOHAMED ALNASSER
IN-PROGRESS
MOHAMED ALNASSER
 MOHAMED ALNASSER
Hi, i am facing problem with input flow. when i made input flow wendow as report form , when i use input flow and i want to use it again , it will save new data and remove old data in CSV & Compain pro. for example i have to report today and i want to save all. please can any one tell me if there is solution ?
Do you mean that if a subscriber goes through the User Input Flow for the second time and provides different data, it replaces the old data? If this is what you mean, then this is how it works. If I misunderstood your point, please explain it again. Thank you
