#655-Pending Campaign not shows in Dashboard Broadcast summary
UNDER-REVIEW
Hello team i found new bug as Pending Campaign not shows in Dashboard Broadcast summary also Time shows wrong on dashboard check highlighted part and compare wiht broadcast details. - @bot-data.s3.ap-southeast-1.wasabisys.com.../livechat-65081-1721403099.png Please check bot SS you will get an idea. - @bot-data.s3.ap-southeast-1.wasabisys.com.../livechat-65081-1721403071.png Along with this Remove K after number like i added 20000 numbers and you shows 20.00K why point and K instead of this correct is 20K only or you remove dot and K please. Make big confusion. thank you
Hello team, I noticed this campaign was totally failed due to panel bug but you deducted credit from my account why? please refund the credit this you have to fix. thank you
We will check the summary of upcoming broadcast campaign and if there any time display issue, we will fix it as soon as possible.
issue is there check and fix
The campaign did not trigger? Please share a screenshot of that campaign. Thank you
